Edison Ortiz Fri, 12/14/2007 - 12:17
  • Hall of Fame,
    Founding Member
Can you provide a particular example ? An administrator must manually enter an IP under the interface, it does not happen automatically.
webbing Fri, 12/14/2007 - 12:29
Thanks for your fast post.I am practicing for my CCNA test, in that process I realize some examples work with VLANs with ip assigned but never saw when it happen they are books examples so basically I can not provide particular examples other than academics.
Edison Ortiz Fri, 12/14/2007 - 12:47
  • Hall of Fame,
    Founding Member
Perhaps the book is skipping the configuration step in order to get to the point they are trying to make a bit faster ...
