Flash Card - Cisco 1801
Dec 14th, 2007
Anyone know what this flash card is used for? Does it hold the nvram as opposed to other boxes (2500, 2600) where its built in to the system?
Jon Marshall Fri, 12/14/2007 - 12:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The flash card is used to hold copy of the IOS/startup config etc. Yes it is built in on some of the older models.
Jon
jzczczc97 Fri, 12/14/2007 - 15:26
Hi, thanks for the response.
When you state it leaves a copy, do you mean a duplicate of the iso and config or does it store the actual ios/config? meaning that the device is useless without the card...?
Jon Marshall Fri, 12/14/2007 - 15:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes, you need the card because this is the only flash.
Jon
