Is the 2950/2960 appropriate for a high traffic production environment?
Dec 14th, 2007
Should I go with a higher end model? If so which.
ccbootcamp Fri, 12/14/2007 - 17:32
  • Gold, 750 points or more
Depends what you call high-traffic, how many ports you need, and what other features you need.
I like the 3750s for high traffic environments due to the stacking capabilities and the single mgmt of multiple switches. Give those a check.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
