7200 local switching interworking between Ethernet Vlan to ATM
Dec 14th, 2007
I want to bridge traffic between ATM interface to Ethernet interface on Cisco7200 as show in attached file. What I want to do in this case is they want to have PVC between 7600 to 2811 . But on the 7600 side is the FEthernet VLAN 802.1q connect to 7200(is the xconnect tranparent bridge) . On the other side 2811 is the CPE connected to FR/ATM network.
I'm trying to think of the best simple way to do this . One of an idea is , Can I use 7200 to perform like SP PE router and do L2VPN local switching on that box ? But I'm not sure if it will work or not. My question is .
1. Can we do local switching on 7200 with L2 interworking between Ethernet VLAN and ATM PVC ?
2. Do we need to configure MPLS or L2TPv3 in this case since there is no MPLS network ?
3. Which IOS is required on 7200?
Or if you have any other suggestion to make the point to point configuration on 7600 to 2811 , please advise.
Thank in advance.
apisak_num Sun, 12/16/2007 - 02:03
This is a same proplem :
I'm trying to get the ATM to ethernet VLAN local switching working properly.
What I'm trying to achieve is to connect a Cisco 828 over an SDSL line using
a VP/VC that terminates on a Cisco 7200. This VC is then connected at layer
2 on the 7200 to a VLAN, which eventually terminates on a Cisco2621.
Physical view:
828 ____SDSL ____ ATM ____ 7200 ____VLAN____ 2621
router DSLAM cloud router router
I can get the 828 to talk to the 7200 at layer 3 no problem, but what I'm
trying to do is get the 828 to see the 2621 as being directly connected at
layer 3 (i.e. the 7200 is transparent). Here is the logical (layer 3) view:
828 ____ 2621
router router
The config I'm trying to use is the following under the fastethernet
sub-interface:
connect connection-name interface pvc interface interworking
interworking-type
This is described in more detail here:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guid
e09186a00801ea88d.html#wp1110021
I'm not having any joy getting this working, so I was wondering whether any
of you have had any experience with this and can help me out?
The 7200 is a 7206VXR running IOS 12.2(25)S1.
Thanks in advance,
Reference url from : http://www.atm.tut.fi/list-archive/nanog/msg36781.html
