792x with VPN
Dec 15th, 2007
I want to use my Cisco 792x IP Phone from any-place ( Wi-Fi) to connect VPN to my network and access the CallManager ?
Does the Cisco 792x has this VPN feature ?
OR
Is there is any software can be installed on the Cisc 792x to create this VPN tubble and access my network ?
Mohamed
ccbootcamp Sat, 12/15/2007 - 02:03
Nope, there's no VPN client available for the 792x phone to allow a VPN tunnel into your network. That would be a cool feature. Take your wi-fi phone to the coffee store with you! Although a softphone on your PC will work. I use it all the time in hotels with high-speed connections. It's pretty decent most of the time.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
