LMS 2.6, Product XXX is not registered with PSU.
andrea.meconi
Level 2
Level 2
CM, CS and DFM are not registered into PSU, so I'm not able to use Device & Software update.
Using CLI:
D:\psu_download>psucli -p cmf -install -src d:\psu_download Mdf
Error : Product cmf is not registered with PSU.
Valid and registered products:
rme ( Resource Manager Essentials )
How can I register a product?
Now, I'm trying to modify tag.properties file.
Thanks.
Andrea.
Joe Clarke
The products are The applications should be registered at install time. The tag.properties file should contain each application's short name and long name mapping, and that file would need to be edited for PSU to know what applications are installed. However, this is not something that should need to be done manually.
For a full LMS installation, tag.properties should look like:
cmf:CiscoWorks Common Services
cvw:CiscoView
nmim:Integration Utility
rme:Resource Manager Essentials
cm:Campus Manager
dfm:Device Fault Manager
ipm:Internetwork Performance Monitor
Once modified, dmgtd will need to be restarted. Additionally, you will need to make sure all of the .info files are in tact under NMSROOT/setup as PSU uses them as well.
Thanks.
I have installed CS, RME, CM and DFM and my tag file contains only the rme entry, so I have added all other applications.
Tomorrow I'll do a check for the .info files.
Thanks a lot.
Andrea.
