12-15-2007 06:26 AM - edited 03-03-2019 07:56 PM
Hello All,
In order to practice frame relay, i configured the following "frame-relay switching" in global int, and "frame-relay intf-type dce" at the int level on these routers (2522, 2621 and 2611XM to one of them a frame relay switch. Unfortunately the command " frame-relay intf-type dce" was not accepted on the three router platforms mentioned.
Are mine doing anything wrong? Somebody please help me out.
12-15-2007 07:23 AM
configure the interfaces encapsulation to FR
Sam
12-15-2007 08:33 AM
This link will guide you on how to configure frame-relay on back-to-back.
http://www.internetworkexpert.com/resources/compound.frame-relay.htm
