PIX password recovery reset settings?
Answered Question
Dec 15th, 2007
Will a PIX password recovery reset all of my settings in the PIX?
Correct Answer by JORGE RODRIGUEZ about 9 years 4 months ago
Austin, password recovery should not reset or change pix configuration other than password recovery only.As far as I know the reseting of PIX configuration is through either write erase or factory default settings commands through config mode. Just follow instructions carefully for password recovery and you should be fine. I would recommend to backup your pix configuration regularly.
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Sat, 12/15/2007 - 07:07
  • Green, 3000 points or more
Rgds
Jorge
