setting up qos for wan
Dec 15th, 2007
Dear experts,
Is there any way to setup dynamic qos for dependant interfaces like atm+serial ?
unfortunatley it is not possible to configure CBWFQ because you can not bind the policy map with the "service policy" command to the interface , actually the interfae does not accept it .
I would realy do appreciate your assistance.
Best Regards,
Farshid
allan.thomas Sat, 12/15/2007 - 10:55
  • Blue, 1500 points or more
In such circumstances use either virtual templates or dialer interfaces, take a look at the PPPoA following example:-
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
bandwidth 1024
ip unnumbered Loopback0
encapsulation ppp
no ip redirects
no ip unreachables
no ip proxy-arp
tx-ring-limit 3
tx-queue-limit 3
dialer pool 1
dialer-group 1
service-policy output QoS-Policy
Another example using ATM interface:-
interface ATM0/1/0
bandwidth 1500
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
pvc x/y
tx-ring-limit 3
vbr-nrt 1500 1500
oam-pvc manage 3
oam retry 5 5 10
encapsulation aal5snap
Example using Serial interface, in this example you have use a class, and within the class you specify the policy:-
interface Serial0/1/0:1
bandwidth 2048
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/1/0:1.10 point-to-point
frame-relay interface-dlci 101 IETF
class QoS-Policy
map-class frame-relay QoS-Policy
frame-relay cir 2048000
frame-relay BC 20480
frame-relay BE 0
frame-relay mincir 2048000
no frame-relay adaptive-shaping
Hope this helps
Allan.
