How to connect back to back two 826 cisco routers via ADSL port?
Dec 15th, 2007
I want to connect two cisco 826 routers using the ADSL ports. As as ADSL is asymmetric ; the upstream on one hand don't match match the download on the other side. How can that be possible.
I want to do this just in order to simulate two LAN
My routers only have one ADSL port, one Ethernet port, and one console port.
Thx for helping
paolo bevilacqua Sun, 12/16/2007 - 07:03
  • Hall of Fame,
    Founding Member
is not possible to connect 826 routers back to back, for the reasons you mentioned.
That would work with 8X8 models.
