DTE Loop on a 1841
Dec 15th, 2007
I am currently trying to loop a Serial0/1/0 interface on to itself. On the 1721 I would just use the loop DTE command under the interface and be able to see the loop, however in a 1841 I am unable to loop the interface using this method. I am wondering if anyone else has seen this, and if there is another way to configure the loop.
Anonymous (not verified) Fri, 12/21/2007 - 13:28
To enable a software loop back the "loopback dte". This command is used to test the performance of the integrated CSU/DSU. Packets are looped from within the CSU/DSU back to the serial interface of the router.
Shaun.proctor Tue, 01/08/2008 - 21:35
When I do this command I am still seeing the interface down/down. When I did it in a 1700 router I always saw the interface up/up looped and was able to run to it. I have tried that command a more than 1 1841 with no luck. Is anyone else seeing this problem?
