ACL on Pix7
Dec 16th, 2007
hi everybody,
does anyone see what's wrong with the acl? although udp 500 is allowed, the pix blocks the traffic.
net1 - pix1 - router - pix2 - net2
%PIX-7-710005: UDP request discarded from 10.4.1.1/1024 to outside:10.2.1.1/500
Pix-1(config)# sal
access-list BLOCK_OUTSIDE; 7 elements
access-list BLOCK_OUTSIDE line 1 extended permit udp host 10.4.1.1 host 10.2.1.1 eq isakmp log debugging
access-list BLOCK_OUTSIDE line 2 extended permit esp host 10.4.1.1 host 10.2.1.1 log debugging
access-list BLOCK_OUTSIDE line 3 extended permit ah host 10.4.1.1 host 10.2.1.1 log debugging
access-list BLOCK_OUTSIDE line 4 extended permit ah host pix2 host 10.2.1.1 log debugging
access-list BLOCK_OUTSIDE line 5 extended permit esp host pix2 host 10.2.1.1 log debugging
access-list BLOCK_OUTSIDE line 6 extended permit udp host pix2 host 10.2.1.1 eq isakmp log debugging
access-list BLOCK_OUTSIDE line 7 extended deny ip any any log debugging
access-list BLOCK_INSIDE; 2 elements
access-list BLOCK_INSIDE line 1 extended permit tcp host A host B eq telnet log debugging
access-list BLOCK_INSIDE line 2 extended deny ip any any log debugging
Pix-1(config)# siib
Ethernet0 10.1.1.2 YES CONFIG up up
Ethernet1 10.2.1.1 YES CONFIG up up
Pix-1(config)# sn
Interface Name Security
Ethernet0 inside 100
Ethernet1 outside 0
Pix-1(config)# sag
access-group BLOCK_INSIDE in interface inside
access-group BLOCK_OUTSIDE in interface outside
any ideas?
tia
tom
srue Sun, 12/16/2007 - 05:40
what device does the address 10.2.1.1 belong to?
is that the inside interface of the pix?
if so, you need to terminate the vpn on the outside interface, and in which case you don't need your acl entries allowing udp/esp/ah to 10.2.1.1 (which should actually be 10.1.1.2 i believe).
i.anfrage Sun, 12/16/2007 - 05:57
Pix-1(config)# siib
Pix-1(config)# sn
Ethernet1 outside 0
Pix-1(config)# sag
it's the outside interface of pix1.
i sure need the acl entries allowing that traffic, cause i 've got a "blocking all ip traffic inside" entry on the inside an the outside interface. i don't want any traffic to be allowed except i allow it explicit. the default is to allow trafic from higher security-level to lower security-level. but i prefer the "checkpoint-default": everything is blocked unless you allow it by a rule.
i hope it's a little bit clearer now.
