cisco 877 router with one Static IP for NAT and PAT
Dec 16th, 2007
Does cisco 877 support single Static Valid IP for NAT and PAT or Do I need an addition Valid IP for PAT ?
I configure the NAT (Dynamic) for my Internal LAN to access the internet, it works fine but I can't get the PAT for port 25 to reach my internal Mail server. I only have one Valid IP address.
Please advice here
dan.cicioiu Sun, 12/16/2007 - 05:55
i think that it should work. Try this :
R1Rack1#sh run | i nat ins
ip nat inside source static tcp 192.168.1.1 25 194.194.194.194 25 extendable
R1Rack1#
R1Rack1#
R1Rack1#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
tcp 194.194.194.194:25 192.168.1.1:25 --- ---
R1Rack1#
Where 192.168.1.1 is your internal smtp server
and 194.194.194.194 is you public ip.
cheeang69 Sun, 12/16/2007 - 13:05
Hi I have tried that already, But I still can't telnet to the public ip address of port 25.
Do you need me to post my config here ?
peteresh87 Mon, 02/18/2008 - 11:21
Just wondering if you have solved the problem,
AS I have pretty much the same issue
Cheers,
peter
