Serial to ethernet converter
Dec 16th, 2007
Dear All,
I am having 30 branch locations and each branch location is connected to central location with 2 Mbps leased line. At the Hub location is it possible for me to pur 30 Serial to Ethernet converter and connect the links to a L3 switch? I want to avoid using a higher end router with 30 2 Mbps interfaces.....
Danilo Dy Sun, 12/16/2007 - 08:00
  • Blue, 1500 points or more
Hard to say, maybe you ask the vendor selling you the converters - ask for POC by trying one or two.
There are other options also, which changing the line to MPLS or MetroE (point-to-multipoint). Check the interface needed, compare the one-time and recuring cost with existing one (including the 30 converter).
Dandy
paolo bevilacqua Sun, 12/16/2007 - 08:34
  • Hall of Fame,
    Founding Member
Hi, a "serial to ethernet converter" is exactly a router, so there is no way you can avoid using one. Check with your SP if they would provide an ethernet interface, that can result more practical for you.
