URL Down action using PTT button on 7921
Dec 16th, 2007
I am having trouble understanding how this PTT button works on a 7921. Using CCM 5.1, I can program the PTT URL and point it to a web server that allows me to capture the request and issue Executes on the appropriate phones. I cannot figure out is when I release the button, how do I stop transmission? Is there a way to capture the button release? I can find nothing on CCO to illustrate this. I guess I am looking to use URLDOWN/URL xml tags that I would normally use on a softkey for applications like intercom or page.
Overall Rating: 5 (1 ratings)
stephan.steiner Tue, 03/25/2008 - 09:20
  • Silver, 250 points or more
Have a button which has the urldown url set to something like
RTPTx:ipaddress:port
And the url set to
RTPTx:Stop
This will transmit while the button is being pressed, and stop transmission when you release it.
Naturally, you could inverse the two to have a mute button.
