SNMP + Null Routes
Dec 16th, 2007
Platform: Cisco 6500, and Cisco 3550
1)I want to read via SNMP, all routes that have been nulled.
2)I want to be able to put in new null routes.
3) I want to be able to remove null routes.
ie: read and write: ip route 1.1.1.1 255.255.255.255 Null0 314324
I've looked and looked but could not find an OID that even came close to this, or any information online how how to add a null route via snmp or add a static route via snmp.
I need this information so I can automate some null routes that our system need to implement from time to time, and remove them as well.
Thank you for your help.
-Gurpreet
Overall Rating: 5 (1 ratings)
Joe Clarke Sun, 12/16/2007 - 21:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Reading routes is doable using the ipRouteTable objects. For example, this CLI:
ip route 10.10.10.0 255.255.255.0 Null0
Would look like the following in the ipRouteTable:
RFC1213-MIB::ipRouteDest.10.10.10.0 = IpAddress: 10.10.10.0
RFC1213-MIB::ipRouteIfIndex.10.10.10.0 = INTEGER: 27
RFC1213-MIB::ipRouteMetric1.10.10.10.0 = INTEGER: 0
RFC1213-MIB::ipRouteMetric2.10.10.10.0 = INTEGER: -1
RFC1213-MIB::ipRouteMetric3.10.10.10.0 = INTEGER: -1
RFC1213-MIB::ipRouteMetric4.10.10.10.0 = INTEGER: -1
RFC1213-MIB::ipRouteNextHop.10.10.10.0 = IpAddress: 0.0.0.0
RFC1213-MIB::ipRouteType.10.10.10.0 = INTEGER: direct(3)
RFC1213-MIB::ipRouteProto.10.10.10.0 = INTEGER: local(2)
RFC1213-MIB::ipRouteAge.10.10.10.0 = INTEGER: 0
RFC1213-MIB::ipRouteMask.10.10.10.0 = IpAddress: 255.255.255.0
RFC1213-MIB::ipRouteMetric5.10.10.10.0 = INTEGER: -1
RFC1213-MIB::ipRouteInfo.10.10.10.0 = OID: SNMPv2-SMI::zeroDotZero
In this example, ifIndex 27 is Null0.
While these objects are read-write, you will not be able to create new routing table entries via SNMP (only modify existing entries).
Creating routes is supported in the new IP-FORWARD-MIB (using the ipCidrRouteTable), but this table is not supported on the 3550, and I do not know what code your 6500 is running.
