TDM link between two voice router
Answered Question
Dec 16th, 2007
i have 1 AS5350 with 4 E1 ports and 2811 with VWIC-MFT module. I want to connect two routers through E1 ports using PRI/CAS signling in order to transfer voice in POTS. Anyone could help me, what type of physical connection should use and the configurations of the two routers.
Thanks in advance.
Correct Answer by Paolo Bevilacqua about 9 years 3 months ago
Forget about CAS that is complicated and doesn't have the good features. Configure one router as network-side PRI, as described at:
http://cisco.com/en/US/docs/routers/access/as5350/software/feature/guide/puldtpri.html
Also remember to place clock source internal under controller E1, for one router only.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 12/17/2007 - 07:34
  • Hall of Fame,
    Founding Member
Just a crossed cable (RJ-48c crossing, NOT ethernet crossing). Note the 2811 must have PVDM2 installed for this to work.
rasankalakmal Mon, 12/17/2007 - 08:50
yes, i have PVDM2 installed. Pls help me with the configuration (using PRI/CAS).
Correct Answer
Paolo Bevilacqua Mon, 12/17/2007 - 09:13
  • Hall of Fame,
    Founding Member
