UCCX 5.0 Recording Script, Prompts being deleted by engine
UCCX 5.0(1)SR02
Hi everyone, got a wierd issue/feature. I have written a script to record, blank and revert prompts, it was all working ok until I went back a couple of days later and found all the prompts I had recorded but weren't there orignally had been deleted and the ones I had recorded and then changed had reverted back to the old pre recording prompts.
I also noted that the prompts don't show up listed under the "Prompt Management".
Any one got any ideas what is going on and what I can do to get around it.
franklopez Sun, 07/20/2008 - 17:04
Anyone have any ideas? I have had two clients have the exact same issue, prompts mysteriously disappear and others revert to previous copies. The last client this happened after 4 - 5 weeks.
Frank
