Fail to Convert Aironet 1242 from lightweight mode back to autonomous mode
Dec 16th, 2007
I just purchased Aironet 1242 access point and want to convert the AP
from lightweight mode back to autonomous mode. I followed the
instruction from Cisco site:
Step 1 The static IP address of the PC on which your TFTP server
software runs should be between 10.0.0.2 and 10.0.0.30. TFTP server
that I use is TFTPD32 which is recommended by Cisco.
Step 2 The PC contains the access point image file (such as c1200-k9w7-
tar.122-15.JA.tar for a 1200 series access point) in the TFTP server
folder and that the TFTP server is activated.
Step 3 On the PC where the TFTP server is located, perform these
steps:
a. Disable any software firewall products, such as Windows firewall,
ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click
Tools > Folder Options > View > Show hidden files and folders.
Step 4 Rename the access point image file in the TFTP server folder to
c1240-k9w7-tar.default for a 1240 series access point.
Step 5 Connect the PC to the access point using a Category 5 (CAT5)
Ethernet cable.
Step 6 Disconnect power from the access point.
Step 7 Press and hold MODE while you reconnect power to the access
point.
Step 8 Hold the MODE button until the status LED turns red
(approximately 20 to 30 seconds) and then release.
Step 9 Wait until the access point reboots, as indicated by all LEDs
turning green followed by the Status LED blinking green.
Step 10 After the access point reboots, reconfigure it using the GUI
or the CLI.
However nothing happen on step 9. I didn't see activity on TFTPD
window. I connect Null Modem cable and I see below error message:
Initializing ethernet port 0
Reset ethernet port 0
Reset done?
ethernet link up, 100 mbps, full--duplex
Ethernet port 0 initialized: link is up
button pressed for 20 seconds
process_config_recovery: set IP address 10.0.0.1
Download tftp:\\255.255.255.255\c1240-k9w7-tar.default
examining image...
Error opening (connection timed out)Loading "flash:/c1130--rcvk9w8--mx/
c1130--rcv event --man
772E6369 73636F2E 63
k9w8--mx".. .
#htII##llft#H##fthttHIft###H#ftfthhttHI#httIft##ft#H##hhtIHI##ft#HH#ft#Hftft#uhIft#uhIflH##
#tI#ll#####llll##llll#hIllll###ll######tI##llll#hIllllll##ll######ll##llllllhIllllll##lluII########llll##llllIItIll
I use 12.3(4)JA2 because I cannot find 12.3(7)JA. On Cisco
instruction, it stated that the image need to be 12.3(7)JA or
earlier. I downloaded the image twice but still not successfull. I
used TFTPD32 software before to upgrade image file on Aironet 1100.
Anyone knows what causing this issue?
irisrios Tue, 12/25/2007 - 06:33
  • Silver, 250 points or more
The error message "Error opening (connection timed out)" indicates something wrong with the IOS file transfer. Check the network connectivity and TFTP server.
Scott Fella Thu, 12/27/2007 - 17:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You see here:
Make sure you rename the file to c1240-k9w7-tar.default
Or try using 3CDaemon for TFTP
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
