pkentsmith Mon, 12/17/2007 - 07:44
You could try checking your switch port for interface resets
Paolo Bevilacqua Mon, 12/17/2007 - 07:46
  • Hall of Fame,
    Founding Member
Please check which FW are you running, from the device status menu. You might need to upgrade it.
Tommer Catlin Mon, 12/17/2007 - 11:42
  • Green, 3000 points or more
I would say you have a flakey POE port or POE problem.
Try plugging in a power brick to the phone to see if it resolves the issue. Then back-track.
Another simple fix would be to switch ports where the phone is plugged into.
I have seen blades in 4xxx go on the fritz with POE problems.
