CCM service release bugs
Answered Question
Dec 17th, 2007
We are running CCM 4.1(3) with SR3. There is a proposal to upgrade to CCM 4.1(3) SR6. Is there a way to find out how many new bugs have been discovered in SR6 ?
Correct Answer by Rob Huffman about 9 years 7 months ago
Hi Abhijit,
How are you my friend, hopefully great! There are no bugs shown yet with SR6, these are always shown under the "known caveats" section of the SR Read-Me notes. Here are the notes for SR6;
http://download-sj.cisco.com/cisco/crypto/3DES/voice/callmgr/4.1/ciscocm.4-1-3-sr6-Readme.htm#_Toc184465225
Hope this helps!
Rob
Overall Rating: 4.5 (2 ratings)
Correct Answer
Rob Huffman Mon, 12/17/2007 - 06:13
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Abhijit,
Hope this helps!
Rob
UCBNOCWAN Mon, 12/17/2007 - 06:24
Rob,
Thanks a lot dear friend. I went through only a part of the release notes today, didn't get the time to read it properly. This definitely helps a lot. Take care,
Thanks & Regards,
Abhijit Das.
Rob Huffman Mon, 12/17/2007 - 06:35
  • Hall of Fame,
    Founding Member
Hi Abhijit,
You are always welcome buddy :) If you are not in a big rush you may want to hold off for a few weeks before installing a new SR like SR6. It only came out on December 3 so new bugs may not have been exposed quite yet. I'm not saying that there will be problems, but it has always been a policy of mine to give a new SR at least a month or so before deployment just to see how people like it :)
Take care,
Rob
UCBNOCWAN Mon, 12/17/2007 - 20:04
Rob,
Thanks a lot for the suggestion. Since it will be a major change in our environment there is the necessity to obtain proper approval & all that stuff. So in all probababilty, nothing will happen before January. My opinion is to upgrade to the latest SR is always the way to go even though there might be some issues. Makes absolutely no sense to raise a change request every month. Btw, I have posted a query pertaining to RTMT, could you please offer some suggestions?
Abhijit.
