6509 interface traffic - network latency
Dec 17th, 2007
Recently I had to trouble shoot 6509 switch, high network latency issue. To my surprise I realized that there is no command (at leat to my knowledge) to check what is the traffic coming in and going out (show mac is giving some octect based output) ... is there any equvilent command for show interface in cisco 6509 switch. Objective is to view the traffic utilization
akachroo123 Mon, 12/17/2007 - 03:51
Try using this command.It will provide u the detail of protocol,Pkts In,Chars In and Pkts out,Chars Out on all the Vlans and the interfaces.
Switch#show interfaces accounting
AK
prasad.gsmc Mon, 12/17/2007 - 03:57
my switch is on cat os and dosent have the optiong
6509-Switch> (enable) show interface ?
MUHAMMAD SHAHEEN Mon, 12/17/2007 - 04:19
Hi Parsad,
try using show counters module/port
for example
Switch1> show counters 7/24
or you can also use
Switch> show counters 7
and it will list counters for all the ports on module 7
Shaheen
