ICMP on Public IP with PAT Translation
Dec 17th, 2007
hi all,
A customer needs to enable ICMP for a public IP with different internal servers...
I have following configuration on a ASA 5520
static (inside,outside) tcp public_IP https 192.168.100.76 https netmask 255.255.255.255
static (inside,outside) tcp public_IP 5405 192.168.100.77 5405 netmask 255.255.255.255
static (inside,outside) tcp public_IP 3389 192.168.100.78 3389 netmask 255.255.255.255
Any ideas to enable ping from outside to the public IP address ??
thanks for informations...
rene
jsivulka Tue, 12/25/2007 - 06:37
  • Bronze, 100 points or more
There are some rate limits in ASA which depends upon the type of packets , So if we flood the ASA with icmp packets then due to the rate limits we will surely see drops.
Ping packets translated when performing PAT on the ASA by Using the icmp id.Any PAT traslation will last for 30 seconds and in case of PAT it is not configurable. Instead if you use NAT then the xlate timeout is configurable using
