Unable to connect to local IP on VPN
Dec 17th, 2007
We have a small office with 3 users in that connect in through VPN Client 4.5.0D.
This works fine, apart from they can't ping any local IP at their end, which is stopping them printing locally through a local IP address. They were using a previous version of the VPN Client which worked except they would get kicked off after 8 hours which wasn't ideal.
VictorAKur Mon, 12/17/2007 - 05:31
If you go into "modify" for the connection you need and click on the tab "Transport" there is an option "Alow Local Lan Access" - tick it and it should help.
helenspencer Mon, 12/17/2007 - 05:34
Perfect, thank you Victor!
Sorry for the stupid question - our WAN guy is on holiday
Helen
VictorAKur Mon, 12/17/2007 - 06:02
You are welcome.
I don't think that any question which ends up here is stupid :)
