RTMT displaying incorrect data
Dec 17th, 2007
We are running CCM 4.1(3) SR3. The issue is - I can see about 193 registered phones in RTMT whereas in CCM administration I have counted approx 220 live phones. ( left out the not registerd, not found ones). Is it hitting some bug??
Overall Rating: 2 (1 ratings)
smalkeric Tue, 12/25/2007 - 06:41
Can you go into the Services page of your system, and take a look at the Cisco RIS Data Collector? What is its Startup Type and is it started? It should be set to Automatic and it should be started.
UCBNOCWAN Thu, 12/27/2007 - 21:41
Thanks for the reply, I checked RIS service, it's started & start-up type is automatic.
