PIX, server, ping problem...
Dec 17th, 2007
Okay I thought I had this problem solved but it seems I have a different problem all together. So here is my situation... I have two servers behind a PIX 501. The PIX has a static external IP, and both servers have their own static external IPs that are being forwarded through the PIX to local IPs. I can ping the PIX from an outside network, but I cannot ping either of the servers external IPs.
Any help will be appriciated here.
Thanks!
Overall Rating: 2.9 (10 ratings)
homeboarder8 Mon, 12/17/2007 - 10:37
Just to give some more information, I have pptp set up for the external IP addresses on the servers. One I am connected through pptp I can ping the internal IP address. Could pptp be the problem?
Thanks.
husycisco Mon, 12/17/2007 - 10:50
  • Gold, 750 points or more
Hi Austin
Try this
access-list outside_access_in permit icmp any host externalIPofserver1
access-list outside_access_in permit icmp any host externalIPofserver2
homeboarder8 Mon, 12/17/2007 - 10:58
Thanks for the response. I tried your recommendations and still I get the "Request timed out" message when trying to ping the servers.
Other ideas?
Just to clarify some things... I am able to PPTP & RDP to the servers. But I am not able to ping the external IP addresses from an external network.
husycisco Mon, 12/17/2007 - 12:06
Please post your config
homeboarder8 Mon, 12/17/2007 - 13:29
PIX Version 6.3(4)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxx encrypted
hostname homeVOIP
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
object-group network pptp_servers
network-object host 74.xx.xx.55
network-object host 74.xx.xx.54
access-list inbound permit tcp any host 74.xx.xx.55 eq www
access-list inbound permit tcp any host 74.xx.xx.55 eq domain
access-list inbound permit udp any host 74.xx.xx.55 eq domain
access-list inbound permit tcp any host 74.xx.xx.55 eq pptp
access-list inbound permit tcp any host 74.xx.xx.54 eq pptp
access-list inbound permit tcp any host 74.xx.xx.54 eq www
access-list inbound deny ip any any log
access-list outbound permit ip 10.0.0.0 255.0.0.0 any
access-list outbound deny ip any any log
access-list acl_inbound permit tcp any object-group pptp_servers eq pptp
access-list acl_inbound permit gre any object-group pptp_servers
access-list acl-inbound permit udp any any eq domain
access-list acl-inbound permit udp any eq domain any
access-list acl-inbound permit tcp any any eq domain
access-list acl-inbound permit tcp any eq domain any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 74.xx.xx.56 255.255.255.248
ip address inside 10.xx.xx.81 255.0.0.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.0.0.0 255.0.0.0 0 0
static (inside,outside) 74.xx.xx.55 10.xx.xx85 netmask 255.255.255.255 0 0
static (inside,outside) 74.xx.xx.54 10.xx.xx.84 netmask 255.255.255.255 0 0
access-group acl_inbound in interface outside
access-group outbound in interface inside
route outside 0.0.0.0 0.0.0.0 74.xx.xx.58 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
acomiskey Mon, 12/17/2007 - 13:37
  • Green, 3000 points or more
access-list acl-inbound permit icmp any host 74.xx.xx.55
access-list acl-inbound permit icmp any host 74.xx.xx.54
access-list outbound permit icmp any any echo-reply
homeboarder8 Mon, 12/17/2007 - 13:43
I entered in the above yet I still cannot ping the external IP addresses. Even when I try to ping from the PIX I get "NO response received".
Other thoughts?
homeboarder8 Mon, 12/17/2007 - 14:49
I'm just throwing stuff out there but could this have something to do with ARP? I did a "show arp" and noticed I there are some different IP addresses stored in there...
homeVOIP(config)# show arp
outside 74.xx.xx.58 0013.f746.d8e3
outside 74.xx.xx.57 0013.1011.2f09
inside 10.xx.xx.84 00c0.9f21.a901
sbaddipu Mon, 12/17/2007 - 15:31
Do you see the pings - echo requests on the server? Sometimes, I have seen office laptops (special images) are configured not to respond to pings? I ended up spending 2 hours debugging a similar issue.
Satya
homeboarder8 Mon, 12/17/2007 - 15:49
Yes I don't think it has anything to do with that. I can ping everything fine (the PIX, other external IP addresses) just not the 2 external IPs for the servers. I did some more debugging and noticed that I cannot ping OUT from the servers either. If you need any other information please let me know.
Thanks!
acomiskey Mon, 12/17/2007 - 16:29
To ping from inside to outside you will need...
access-list acl-inbound permit icmp any any echo-reply
jfbeam Mon, 12/17/2007 - 16:53
For starters, pick an access list name and stay with it. You have *3* "inbound" acl's defined: (1) inbound, (2) acl_inbound, and (3) acl-inbound. Notice the underscore vs. dash. "acl_inbound" (underscore) is the one that's active. This is why I dislike access-lists; call me old, but "conduit permit icmp any any" has never failed me.
Your outbound filter is unnecessary under normal circumstances. The access list ("outbound") doesn't have anything to block unless something on the internal network is screwed up. Unless management software complains about not having this filter, I'd remove it. People always forget they have to allow traffic in both directions. (Add a vote for conduits. *grin*)
Your inbound acl (and lets settle on "inbound") needs to allow icmp in (and the replies back out if there's a filter in the other direction.)
! "inbound"
clear access-list inbound
access-list inbound permit icmp any any
access-list inbound permit tcp any object-group pptp_servers eq domain
access-list inbound permit tcp any object-group pptp_servers eq www
access-list inbound permit tcp any object-group pptp_servers eq pptp
access-list inbound permit gre any object-group pptp_servers
access-group inbound in interface outside
As it stands, the outbound list will not prevent icmp traffic -- ip includes icmp.
If that still doesn't work, "conduit permit icmp any any" will. ('tho management software tends to complain about using conduits.)
Note about "conduit": Cisco depreciated conduits a long time ago. However, current versions of PDM (3.0+) don't complain about them and will actually create them. So, they aren't as Evil(tm) as Cisco once taught.
homeboarder8 Mon, 12/17/2007 - 17:53
Okay so from what I understand, I should delete the acls inbound and acl-inbound and replace them with the acl inbound above?
Thanks for your help!
jfbeam Mon, 12/17/2007 - 19:12
They're not being used, so they just take up space (and confuse people.) I rolled them all into "inbound".
And the domain line should be udp, not tcp.
access-list inbound permit udp any object-group pptp_servers eq domain
(tcp is only used for zone transfers.)
husycisco Tue, 12/18/2007 - 00:03
Make sure software firewalls installed on server permit ICMP (Like windows firewall) try temporarily disabling then ping
acomiskey Tue, 12/18/2007 - 06:58
jfbeam, ip does not include icmp.
homeboarder8 Tue, 12/18/2007 - 07:26
Okay here is where I stand. I can now ping out from the server, but still I cannot ping the external IP addresses of either of the servers. Note that I am using a static route for the external IPs to the internal ones (Not sure if that makes any difference). But here is the updated running config:
PIX Version 6.3(4)
enable password xxxxxxxxxxxx encrypted
passwd xxxxxxxxxx encrypted
hostname homeVOIP
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
static (inside,outside) 74.xx.xx.55 10.xx.xx.85 netmask 255.255.255.255 0 0
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Thanks again for all the help.
acomiskey Tue, 12/18/2007 - 09:03
You have to allow the ping reply in your outbound acl since ip does NOT include icmp.
homeboarder8 Tue, 12/18/2007 - 12:17
Okay I entered that access-list in but I still cannot ping the external IP addresses...
husycisco Tue, 12/18/2007 - 12:53
If following commands do not work, I recommend you to upgrade your IOS to 6.3(5)
no conduit permit icmp any any
conduit permit icmp host 77.xx.xx.55 any
conduit permit icmp host 77.xx.xx.54 any
icmp permit any outside
one last possibility if above does not work
no floodguard enable
again double-check if ICMP is enabled in any software firewall (make sure it is not allowed to a specific range of IPs, like windows firewall options)
homeboarder8 Tue, 12/18/2007 - 15:34
I entered your settings, and still it does not work. Could you point me in the right direction to upgrade to firmware?
Thanks.
homeboarder8 Tue, 12/18/2007 - 19:37
I entered your settings and I am still not able to ping the servers. Can you point me in the right direction as to where I can download the updated firmware? And I am still open to other ideas....
Thanks for the help!
homeboarder8 Thu, 12/20/2007 - 10:06
I upgraded the firmware but the problem still exists. Could this have something to do with the static routes? And if I set my servers to the external IPs could I still use PPTP for secure remote connections?
Thanks!
