TCP Probe failure on CSM
Dec 17th, 2007
  • Silver, 250 points or more
I have had a customer raise an issue with me. Unfortunately I am not too hot on the CSM.
Switch Type - Cisco WS-C6513
IOS VSN - 12.2(18)SXF4
CSM Module details
Card Type - SLB Application Processor Module
Model - WS-X6066-SLB-APC
Hardware VSN - 1.8
Software VSN - 4.2(5)
I have spotted bug CSCsc38892, but cannot tell if the catakyst is running VRF - this is all the info I have been given.
We have 6500 chassis each with a CSM module in fault tolerance (ft) mode.
The current standby module (at the time it was the active one) reports as per output below that probes failed:
sh mod csm 1 real sf SAPCCP
real server farm weight state conns/hits
10.xxx.xxx.xxx:8000 SAPCCP 8 PROBE_FAILED 0
Probe failed could be for a number of reasons however the inconsistency is that the failed probes follow the CSM module and that the other module has working probes.
It is to be noted that the command “ping module csm 1 10.xxx.xxx.xxx” reports to be reachable as a good indicator that there is connectivity from the CSM to the server.
The following is the output from the currently active CSM (which used to be the standby one):
10.xxx.xxx.xxx:8000 SAPCCP 8 OPERATIONAL 51
10.xxx.xxx.xxx:8000 SAPCCP 8 OPERATIONAL 41
10.xxx.xxx.xxx:8000 SAPCCP 8 OPERATIONAL 52
For info:
FUNCTIONING CSM
sh mod 1
Mod Ports Card Type Model Serial No.
1 4 SLB Application Processor Complex WS-X6066-SLB-APC SAD094803UC
Mod MAC addresses Hw Fw Sw Status
1 0015.f998.a94a to 0015.f998.a951 1.8 4.2(5) Ok
Mod Online Diag Status
1 Pass
relevant config lines
serverfarm SAPCCP
nat server
no nat client
failaction purge
real 10.xxx.xxx.xxx 8000
inservice
inservice
inservice
probe ABAP
vserver SAPCCP-VIP
virtual 10.xxx.xxx.xxx tcp www
vlan xxx
serverfarm SAPCCP
sticky 15 group 117
replicate csrp sticky
replicate csrp connection
no persistent rebalance
parse-length 4000
inservice
probe ABAP tcp
interval 2
retries 2
failed 6
open 3
port 8000
paul.matthews Mon, 12/17/2007 - 07:03
Continued:
NON-FUNCTIONING CSM
sh mod 1
1 4 SLB Application Processor Complex WS-X6066-SLB-APC SAD094609ZZ
1 0015.f998.8386 to 0015.f998.838d 1.8 4.2(5) Ok
1 Pass
serverfarm SAPCCP
nat server
no nat client
failaction purge
inservice
inservice
inservice
probe ABAP-CCP
vserver SAPCCP-VIP
virtual 10xxx.xxx.xxx tcp www
vlan xxx
serverfarm SAPCCP
sticky 15 group 117
parse-length 4000
inservice
probe ABAP-CCP tcp
recover 2
interval 6
retries 2
failed 6
open 5
port 8000
Thanks for any pointers on where to look,
Paul.
tporembski Tue, 02/03/2009 - 09:39
I would check the ARP table on both CSMs and make sure it is correct for the servers in question.
Gilles Dufour Wed, 02/04/2009 - 03:05
  • Cisco Employee,
Get a sniffer trace on the standby CSM.
See if the probes are fired or not and if the does get a response from the server.
G
