12-17-2007 07:56 AM - edited 03-09-2019 07:39 PM
I am trying to update my CS-MARS 50 to 4.1.4, and am reading quick install and release notes for this version. It tells me I need to install this pnlogagent.exe before I can upgrade the MARS version. Is this only required if I am sending ACS syslogs to the MARS? Thanks, Tony
Solved! Go to Solution.
12-17-2007 09:25 AM
You don't need to worry about it unless you actually using the old 1.0 agent, which does actually run on the ACS server.
12-17-2007 09:10 AM
yes, the upgrade is only required if you're using Cisco ACS and more specifically the old 1.0 version of pnlogagent.
12-17-2007 09:20 AM
We are using ACS, however, currently are not logging to the MARS from the ACS server. At some point we might, so do I need to worry about this pnlogagent now? If so, how do I get to where I can see what version the ACS is running currently? I'm assuming this file runs on the ACS? Thanks, Tony
12-17-2007 09:25 AM
12-17-2007 12:20 PM
Okay, thanks for the help.
