Preparing for CCVP Lab (NFR program)
Dec 17th, 2007
Hi, i'm working for a cisco's partner and i wanna know before contacting our channel partner if this product number include only a licensing or it's a full software and include the licensing won it self :
UC6.0-K9-NFR It's the Cisco CallManager 6.0 NFR Program and last questions wich MCS server do i have to purchase so does the MCS 7816 H3 can do the work! thanks for your support guys i'm really greatful to this forum and to all the engineers working on it thanks again :)
Rob Huffman Mon, 12/17/2007 - 10:08
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Seif,
Hope all is well with you :) Here is the info for CCM 5.x NFR Kits which is the same for 6.x NFR Kits;
Partners can purchase not-for-resale (NFR) licenses at discounted levels off the wholesale price list. The part numbers begin with CM5.1-K9-NFR for the Cisco Unified CallManager software, including a media kit and Product Authorization Key PAK. Then they will purchase device license units and phones, other applications, etc. according to what is required for the demo.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item0900aecd805a7062.shtml
This doc shows all the supported models for the different CCM Versions (it does show support for the MCS7816 H3 with CCM 6.0);
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
