12-17-2007 08:51 AM - edited 03-15-2019 07:49 AM
i have PRI's to the telco with CME 4.2 and i sending the CallerID to telco switch. The telco do not see my caller id name, but see my caller id number!
I have tried to configure "isdn supp-service name calling" but no success
Any ideas?
Brian
Solved! Go to Solution.
12-17-2007 10:15 AM
You are sending a name:
Display i = 'Arc Operator 1'
But as mentioned before, it is rightly ignored by telco.
12-17-2007 09:00 AM
Probably even if you send a name to PSTN, it will not make any difference. The reason is because you could impersonate a third party, or use an offensive name, so telco just ignores names.
However, the command to do so, is: "isdn outgoing ie display".
12-17-2007 09:55 AM
thank you for your help!
but i alrealdy did that command:
This is my config
interface Serial0/0/0:23
isdn switch-type primary-ni
isdn incoming-voice voice
isdn outgoing display-ie
12-17-2007 10:00 AM
That makes the name to go out as display IE:
Dec 17 17:57:45.574 CET: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8 callref = 0x42
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = 'P. Bevilacqua'
Calling Party Number i = 0x0080, '28'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '187'
Sending Complete
Then as mentioned before, when connecting to PSTN, it won't make any difference if you send a name or not.
12-17-2007 10:03 AM
yes let me see what name it is send it
you a debug isdn q931 to have that result ?
12-17-2007 10:07 AM
Yes. Alway have debug isdn q931 when doing isdn things.
12-17-2007 10:12 AM
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x1B16
Bearer Capability i = 0x8090A2
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A116020173020100800E417263204F70657261746F722031
Protocol Profile = Networking Extensions
0xA116020173020100800E417263204F70657261746F722031
Component = Invoke component
Invoke Id = 115
Operation = CallingName
Name Presentation Allowed Extended
Name = Arc Operator 1
Calling Party Number i = 0x2180, '4188711622'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '4182645859'
12-17-2007 10:13 AM
i SEE THE NAME Name = Arc Operator 1 ,
BUT IT IS NOT SHOWING UP AT THE PROVIDER
THE TELCO IS BLOCKING MY CALLER ID NAME?
12-17-2007 10:15 AM
12-17-2007 10:17 AM
OK, I UNDERSTAND, IF TELCO IGNORED MY CALLER id
HOW COMES I CANNOT SEE IT ON REMOTE PHONE UNDER A PSTN NETWORK?
12-17-2007 10:26 AM
Hi, this is exactly because telco ignores your caller name, so you do not see on a remote phone.
Imagine if anyone was allowed to send profanities as a name, would you like that ?
Telco network is not a chatline where you can choose name as you better like :)
12-17-2007 10:29 AM
BUT I CALLED TELCO AND THEY TOLD ME THAT HE IS NOT BLOCKING ANYTHING .. ..:( I WILL CALL THEM TO TROUBLESHOOT THAT ISSUE WITH THEM .. Thanks
by the you are ccie the exam was difficult?
12-17-2007 10:33 AM
Hi, telco will always reply "we do not block anything" to avoid discussions -- even if they don't even understand the question.
And yes, the CCIE exam is very difficult.
Thanks for the nice rating and good luck!
