3750 Stack Reloads
Dec 17th, 2007
Does anyone know of any known issues in which a single switch in a stack is reloaded but additional switches will restart as well? For example, in a 5 switch stack, switch 3 is reloaded. Switch 1 and 2 reload as well.
carenas123 Tue, 12/25/2007 - 07:03
  • Silver, 250 points or more
The only way to determine this is to look at the logs or state of the switch just
before a reload. This can be achieved by setting up a logging server at a remote location
and let it record all the logs from the switch. When the switch reloads the information is
removed so we really cannot do much with the switch after a reload.
c-wilkins Wed, 12/26/2007 - 13:28
We do have all of our switches pointed to a logging server and have checked the logs prior to doing this. There is never any logs that point to something wrong with the switch prior to it restarting.
glen.grant Tue, 12/25/2007 - 10:51
  • Purple, 4500 points or more
Did you just reload switch 1 ? If you just do a normal reload command I believe it will reload the whole stack if you don't specify which switch to reload .
c-wilkins Wed, 12/26/2007 - 13:16
No, we used the reload slot 4 for example to reload switch 4. When we do this, some additional switches reload in the stack as well, and some in the stack do not reload.
pornthip_k Tue, 05/13/2008 - 04:12
Dear Sir,
I got the problem like you.
If you already resolve this problem,, Could you please tell me how to make this point disappear?
Thank you,
Natchamon
