Can't access Webserver behind Pix 501 - Nat problem?
Answered Question
Dec 17th, 2007
I have Pix 501 in front of a webserver and I am unable to bring up any website off of the webserver. Here is some of my config:
access-list InboundFilter permit tcp any host XXX.XXX.XXX.XXX (my public IP) eq www
http server enable
http 192.168.1.0 255.255.255.0 inside
static (inside, outside) tcp XXX.XXX.XXX.XXX www 192.168.1.1(webserver) www netmask 255.255.255.255 0 0
Everything else works fine. I am able to surf the internet, ping, etc. without a problem. Just accessing the webserver from outside my network is the problem. I have verified ip, routes, gateway etc on my webserver and everything is correct.
I am using just one public IP for everything. I have always used two, one for PIX public IP and a separate one for websites. I am waiting for a second from ISP, but in the meantime I would like to get this working. Thanks in advance for any help.
Correct Answer by acomiskey about 9 years 4 months ago
access-list InboundFilter permit tcp any host 192.168.1.10 eq www
should be...
access-list InboundFilter permit tcp any host eq www
Overall Rating: 5 (1 ratings)
acomiskey Mon, 12/17/2007 - 09:14
  • Green, 3000 points or more
Make your static...
static (inside, outside) tcp interface www 192.168.1.1 www netmask 255.255.255.255 0 0
acomiskey Mon, 12/17/2007 - 10:28
Do you have...
access-group InboundFilter in interface outside
Robeasts99 Mon, 12/17/2007 - 11:08
Yea I do have that, sorry I left that out. More info...
global (outside) 1 interface
nat (inside) 0 access-list nonat (No Nat'n for my VPN Client)
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
Thanks again.
Robeasts99 Mon, 12/17/2007 - 11:34
Thanks again.
husycisco Mon, 12/17/2007 - 11:51
  • Gold, 750 points or more
Robert
Your running config would help. Your webserver entry may exist in exempt nat and may flow through exempt NAT before your static. Also enter www.whatismyip.com in webserver and check if you are trying to browse the right IP& assigned static to right IP
Robeasts99 Tue, 12/18/2007 - 06:31
Here is my running config...
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list InboundFilter permit icmp any any
access-list nonat permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside XXX.XXX.XXX.XXX 255.255.255.252
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool itpool 192.168.100.50-192.168.100.60
pdm history enable
arp timeout 14400
static (inside,outside) tcp interface www 192.168.1.10 www netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
...the rest is my VPN stuff. Also I verified the IP and it is correctly resolving to the right IP. Thanks again for all the help.
Correct Answer
acomiskey Tue, 12/18/2007 - 06:55
should be...
psureshrao Tue, 12/18/2007 - 07:11
Adding to acomiskey reply the acl should be like that and
If i am wrong please correct me.
Also make sure disable the http in PIX.
Because if your webserver is natted on the outside interface IP,PIX is also acts as HTTP server.
disable http: no http server
other wise make PIX as https and your webserver use http.
husycisco Tue, 12/18/2007 - 07:22
Suresh,
That would be a concern if it was SSL port, not www.
Also wont affect with the above config since http is enabled for inside only.
husycisco Tue, 12/18/2007 - 07:18
Robert
Do the following modification exactly in its respective order
no access-list InboundFilter permit tcp any host 192.168.1.10 eq www
access-list InboundFilter permit tcp any interface outside eq www
