5505-can't connect to ASDM in transparent mode
Dec 17th, 2007
Hello, I'm setting up an ASA 5505 in transparent mode. I can ping the ASA device on the network but I cannot connect via ASDM software. When I revert back to routed mode, no problems using ASDM. I'm connecting via enet cable from laptop to Ethernet 0/1 interface on ASA 5505. I try the 'http ipaddress subnet' command and it won't take it even tho it's the same IP as the device. Do the 'switchport access' command to E 0/1 and doesn't stick. Here's my config if it helps. I really appreciate your help!
firewall transparent
hostname ciscoasa
domain-name xxxx.state.tx.us
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxx encrypted
boot system disk0:/asa803-k8.bin
ftp mode passive
dns server-group DefaultDNS
access-list OUTSIDE-IN extended permit ip any any
pager lines 24
mtu inside 1500
mtu outside 1500
ip address xxx.xx.xx.xxx 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
