"Authorization Failed" Error recovering 3750 password
Dec 17th, 2007
trying to recover password on a
3750-48TS-E. i initialized the flash, loaded helper, renamed config.text, etc,etc, now when i try to configure teminal i get an "Authorization Failed" error...........what to do?
Overall Rating: 5 (1 ratings)
Edison Ortiz Mon, 12/17/2007 - 09:58
After renaming the config.text and doing the 'boot', the running-configuration should be empty.
Is that the case here ?
Did you copy the renamed config to running-config ?
If so, it will bring the AAA configuration into running-configuration.
Do a more flash:[config.file], copy the configuration onto an editor and remove the authentication part, then paste the modified configuration into running-config.
larryfocust Mon, 12/17/2007 - 10:19
yes i renamed and copied the config to running config. i've never done a more flash:[config.file], how to?
Edison Ortiz Mon, 12/17/2007 - 10:25
more is a command to display the content of the file in the router's CLI.
dir flash:config.text
Directory of flash:/config.text
5 -rwx 2129 Mar 1 1993 00:02:50 +00:00 config.text
sw1#more flash:config.text
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
Richard Burts Mon, 12/17/2007 - 11:02
I am a bit confused about what is going on. As Edison has pointed out if you rename the config file and boot then you should come up with an essentially empty config (especially the config should not have aaa authorization commands in it). But the symptoms of getting authorization failed would indicate that that it is executing aaa authorization commands. Can you clarify the steps that you have taken that lead to these symptoms?
larryfocust Mon, 12/17/2007 - 11:09
Hi Rick, well,
then I check "dir flash:"
rename flash:config.text flash:config.text.old
type "no" for config dialog
type "enable"
rename flash:config.text.old flash:config.text
copy flash:config.text system:running-config
Source filename [config.text]?
Destination filename [running-config]?
Press Return
configure terminal
that is when I get the Authorization Failed error. plus when I try the "more" command, i get the same error
Richard Burts Mon, 12/17/2007 - 11:49
Thanks for the additional information. I believe that the issue is that when you do this step:
that it brings the original config, including its aaa authentication and aaa authorization commands into the running config. And there is some issue with the aaa authorization command.
I wonder if the solution might be to do a copy and paste of parts of the original config (to get the functions that you need) and to make appropriate modifications in the aaa commands before you paste them into the running config?
Edison Ortiz Mon, 12/17/2007 - 11:57
Please follow these steps in your instructions:
type "enable"
more flash:config.text.old
copy and paste the output onto notepad
remove the aaa entries
copy and paste the modified config onto the router in configuration mode
then do a write memory
No need to rename the file back.
larryfocust Mon, 12/17/2007 - 13:09
Ed, the output is QUITE long. Is there an easier way to capture the complete file than to copy/paste screen by screen?
Edison Ortiz Mon, 12/17/2007 - 13:43
Your terminal application should give you an option to save the output to a file.
larryfocust Mon, 12/17/2007 - 13:54
Ed, i got it but the file is 20 pages long.
it list a revision history, new switch steps,misc global controls,ip specific global commands,spanning tree global commands, aaa new-model (!defined shared key)(!ordinary logins)(!priv access)(!require Authorization WHENEVER user issues a command)(aaa auth network)(aaa auth exec)(aaa accounting exec)then all commands per port........
Edison Ortiz Mon, 12/17/2007 - 14:43
On that file, just remove the aaa entries and copy and paste it back onto the switch while in configuration mode.
larryfocust Mon, 12/17/2007 - 14:49
Thanks Ed, I'll give it a shot............
Thanks for all the help.........
larryfocust Tue, 12/18/2007 - 13:23
Ed, Rick, Thanks for all the help. I can finally get this thing off my bench.
