Can the DSL FW of a Cisco 837 be updated?
Answered Question
Dec 17th, 2007
I have a Cisco 837 and wondered if the DSL FW can be upgraded like the 877's can? Here's it's output.
Router#sh dsl int atm0
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT)
ITU STD NUM: 0x01 0x01
Vendor ID: 'ALCB' 'GSPN'
Vendor Specific: 0x0000 0x0008
Vendor Country: 0x00 0xFF
Capacity Used: 96% 59%
Noise Margin: 4.0 dB 14.0 dB
Output Power: 19.0 dBm 3.5 dBm
Attenuation: 45.5 dB 31.5 dB
Defect Status: None None
Last Fail Code: None
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 646 (1 spurious)
Activations: 1
Init FW: embedded
Operartion FW: embedded
SW Version: 3.9.220
FW Version: 0x1A04
It disconnects a few times a day, if not I guess I will have to upgrade to an 877.
Correct Answer by Paolo Bevilacqua about 8 years 10 months ago
Hi, according to:
you are running latest FW and cannot be upgraded. Some tweaking can be tried with dsl command, but personally I'm always a bit way of that.
Overall Rating: 3 (1 ratings)
