12-17-2007 11:20 AM - edited 03-05-2019 08:02 PM
How to do nating for a network that is not directly connected to a router (routed network) ????
example:
two routers that is directly connected one of them connected to internet and the other one connected to internal network....
12-17-2007 11:42 AM
Natting does not mandate that the networks need to be directly connected.
For example
(10.10.10.0/24)R1 <--> R2 <--> R3(100.100.100.0/24)
On R3 you can configure
ip nat pool MYNAT 100.100.100.20 100.100.100.20 prefix-length 24
ip nat inside source list 100 pool MYNAT overload
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
interface
ip nat inside
interface
ip nat outside
This sort of situation can be generally seen on the perimeter firewall facing the interanet which translates all the internal address to a glabal public ip pool for routing over the internet and the source networks are mostly not dorectly connected
Narayan
12-17-2007 12:04 PM
Thanx royalblues
