JORGE RODRIGUEZ Mon, 12/17/2007 - 14:34
  • Green, 3000 points or more
The maximun memory 515x boxes can support is 128, but depending on license the minimun memory requirements is noted, link bellow gives you detailed specs .
License bundle specs .
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a00800b0d85.html
Mem installs and other specs if upgrading code
http://www.cisco.com/en/US/docs/security/pix/pix70/hw/installation/guide/515.html#wp1030778
For memory upgrade this link has the best memory price in town that I have seen !
http://www.memoryx.net/pixfirewall.html
Rgds
Jorge
shanemonson Tue, 12/18/2007 - 10:07
hmmm... while waiting for this reply I went ahead and added an addl 128mb dimm of PC100 sdram for a total of 192mb, and it's working. Show memory indicates the correct amount as does ASDM 6.03. Is this OK? ASDM actually shows the current used mem as 109mb. When the system only had 64mb, it showed 42mb used? Does the PIX throttle memory based on what's avail?
JORGE RODRIGUEZ Tue, 12/18/2007 - 11:40
Shane, I have not face yet this scenario in adding additional memory to PIX than the actual posted by specifications, perhaps someone in forum may comment on overall Fw code functionality in this type of scenario. Personally I tend to go by the book when in comes to hardware and firewalls simply to avoid risks of problems in network production, if it was in the case of personal firewall labs scenario sure, I would go ahead and install memory but I would fully test fw functionality.
Rgds
Jorge
shanemonson Tue, 12/18/2007 - 13:57
This PIX is in a lab environment -
Does the PIX throttle resources based on available memory?
By limiting the memory and runing OS version 8.0.3 and ASDM 6.03, are we hindering performance or functionality?
