Wireless Bridge blocks broadcast packets
Dec 17th, 2007
Hi, I have some difficulty to make a wireless bridge totally transparent.
A wireless bridge created on two AP1242AG Access Points to connect two physical networks. Access points are configured as root-bridge and non-root bridge.
Bridge SSID is up and running, user behind non-root access points can not get a dhcp address, because no broadcast packets are flooded to the root bridge side which is the dhcp server resides.
Any ideas?
ivillegas Tue, 12/25/2007 - 07:39
  • Silver, 250 points or more
By default the traffic is not blocked. Check if there are any filters configured on the bridge that is blocking the UDP port 67 and 68 which is meant for DHCP traffic. If not try rebooting the bridge.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
