can ciscoview show the Gbic modules on 6509e
Answered Question
Dec 17th, 2007
hi
i use ciscoworks snms 1.5.1 with common service 2.2 and ciscoview 6.0. when i open my 6509 switch ciscoview show only unsupported card on the slot. all the cards are gbic modules. can i update the ciscoview for this. thanks
Correct Answer by Joe Clarke about 9 years 2 months ago
You can upgrade the CiscoView device packages for your device. You can find all CV packages at http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi .
Overall Rating: 5 (1 ratings)
