Jumbo Frame support
Dec 17th, 2007
I have enabled all my 3750G switches with:
system mtu jumbo 9000
Should I leave the system routing mtu set to default (1500) ?
I am using all gigabit ports. No 10/100 ports.
I read that the 3750 only support like 1998 mtu for routing.
Someone please advise.
Edison Ortiz Tue, 12/18/2007 - 08:25
  • Hall of Fame,
    Founding Member
If you are using OSPF, I highly recommend leaving it to 1500. OSPF uses MTU for neighbor adjacency.
Correct.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/cr/cli3.htm#wp1948947
