Ext mobility faiover not working - Cisco Document is incorrect ?
Dec 17th, 2007
know that Ext mobility failover is best supported in CCM ver 6.X.
I am refering to CCM 5.0 Developers guide, under " cisco extension mobility API programming" - under " faiover support" in the following doc link;
Where it says we can configure external DNS server to point the server IPs in the cluster.
I have tried to implement this but, even if I configure the IP address manually to point out the subscriber and when I simuloate the publisher failure, following happens;
1. Users who already logged in cannot log out ( they cannot call ext mobility service which already has been subscribed to dev profile).
2. New users cannot still log in ( There is no respose when they select the Exct mobility service which now pointed to the subscriber server ).
Does this mean that I am missing something ? OR is this document itself is misleading ?
Overall Rating: 5 (1 ratings)
Sascha Monteiro Thu, 12/20/2007 - 11:15
only in 6.x you can have feature redundancy if the Publisher is down...
The example you mention is if a subscriber is down and you will the use another subscriber to interface the EM (and NOT if Pub is down)
