SSL termination on CSS11501 using host headers and single VIP
Dec 17th, 2007
I have a requirement to do SSL transparent proxy for multiple websites sharing the same VIP. I want to use the host header information from the client to decide which certificate to use.
I can't seem to find anything in the documentation on how to do this (if indeed it can be done).
I have tried to enter the same VIP on two servers in the SSL proxy list, but when I activate it I get the message:
Ssl-servers 30 and 40:
%% Cannot have same virtual Ip:port combination on two ssl-servers
Anyone out there know if this can be done?
Andrew
Gilles Dufour Wed, 12/26/2007 - 02:45
the host header is also encrypted.
So, you can't use this information to decide which key/certificate to use to decrypt the traffic.
This is a protocol limitation.
So you need to use one ip address/tcp port per certificate.
Gilles.
andrew-kearton Wed, 12/26/2007 - 13:42
Hi Gilles,
Thanks for the reply. I have heard about "wildcard certificates" that support unlimited subdomains e.g certificate for
"*.abc.com" will support uat.abc.com, prod.abc.com, test.abc.com, dev.abc.com etc
Are these supported by the CSS, and would this be a way around the problem?
Andrew
Gilles Dufour Thu, 12/27/2007 - 02:07
yes, the CSS support wildcard certificate.
But a wildcard cert is usally given to a company.
So as you said, something like *.company.com.
G.
