CCVP lab with frame switch
Answered Question
Dec 17th, 2007
I want to have a good frame switch. I saw some Cisco 2521 routers on EBAY for very cheap. Can I use one of those?
Correct Answer by ccbootcamp about 9 years 3 months ago
On some serial interfaces, yes, you can set the clock rate higher. On the NM-4A/S which we use, no, 128kbps is the highest clock rate it will take. Same thing with 2 of the 4 ports on the 2521 you are looking at purchasing (it has 2 low speed serial ports and 2 high speed serial ports).
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Here ya go:
frame-relay switching
interface Serial1/1
description FR to BR1
no ip address
encapsulation frame-relay IETF
no fair-queue
clock rate 128000
no dce-terminal-timing-enable
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 101 interface Serial1/3 201
no shut
interface Serial1/2
description FR to BR2
no ip address
clock rate 128000
frame-relay route 102 interface Serial1/3 202
no shut
interface Serial1/3
description FR to HQ
no ip address
clock rate 128000
frame-relay route 201 interface Serial1/1 101
frame-relay route 202 interface Serial1/2 102
no shut
note: you will have to modify the interfaces to fit your router.
-brad
www.ccbootcamp.com
Yes, you can definitely use that for a frame switch. We use a 2811 as our frame switch and the PSTN cloud. But if you want to save some $$ a Cisco 2521 or 2520 has four serial ports and will do just fine.
-brad
www.ccbootcamp.com
Overall Rating: 5 (3 ratings)
Correct Answer
ccbootcamp Mon, 12/17/2007 - 22:02
  • Gold, 750 points or more
-brad
www.ccbootcamp.com
SteveDexter Mon, 12/17/2007 - 22:09
That is good news. I saw one for $25. Do you have a configuration I can use?
Correct Answer
ccbootcamp Mon, 12/17/2007 - 22:17
Here ya go:
interface Serial1/1
no ip address
no fair-queue
clock rate 128000
no shut
interface Serial1/2
no ip address
clock rate 128000
no shut
interface Serial1/3
no ip address
clock rate 128000
no shut
-brad
www.ccbootcamp.com
SteveDexter Mon, 12/17/2007 - 22:21
I noticed the clock rate above is set at 128000. Will that cause a problem with my lab and passing voice traffic? Can I set my clock rate higher?
Correct Answer
ccbootcamp Mon, 12/17/2007 - 22:25
-brad
www.ccbootcamp.com
