12-17-2007 10:36 PM - edited 03-03-2019 07:58 PM
i would like to use the GLBP to do the load balance with my network. but the out come was not my expected when the wan link downed
i can use the MHSRP and two eigrp to complete the requirement. but the GLBP can not do it
requirement
1. the standby router will take all traffic when the active router its s0/0/0 interface down
2. The standby router will take all traffic when the active router opposite router ethernet down
Testing procedure
when i shutdown the s0/0/0 in the active router, the other forwarder can not take the active router traffic. the tracert from site B to site A diagram site_B_pc2_tracert1.jpg shown the destination host unreachable.
My design use two EIGRP to check the opposite ethernet network
attached show glbp, tracert files from site B to Site A
Please help me if you can
Solved! Go to Solution.
12-19-2007 12:49 PM
I verified your configs. Please make the following changes.
SiteA Router1, remove:
glbp 10 priority 100
SiteA Router2, remove:
glbp 10 priority 95
Do the same on SiteB routers.
Unlike HSRP, priority does not decrement in GLBP, you decrement the weight.
I tested your config in a lab
________________________________
192.168.101.0/24 represents an external network on this sample:
From a device behind the GLBP
trace 192.168.101.1
Tracing the route to 192.168.101.1
1 192.168.2.102 0 msec 0 msec 0 msec
2 10.0.0.1 26 msec * 25 msec
Right now, R2 is handling the forwarding for this device.
If I go to R2 and shut down the serial interface.
sh track
Track 1
Response Time Reporter 1 reachability
Reachability is Down
10 changes, last change 00:00:20
Latest operation return code: Timeout
Tracked by:
GLBP FastEthernet0/0 10
The trace goes to R1:
trace 192.168.101.1
1 192.168.2.101 9 msec 0 msec 0 msec
2 10.0.0.1 33 msec * 26 msec
12-19-2007 12:49 PM
glbp 10 priority 95
trace 192.168.101.1
sh track
Track 1
Tracked by:
trace 192.168.101.1
12-19-2007 07:58 PM
Dear EdisonOrtiz
Thanks for your reply, as i know that the priority value is to determine the AVG on this group routers, do you agree ? i did the tested but the result still get the same problem when the tracked object down. fortunately, i found the other command on the
cisco and modified my config as below
glbp 10 weighting 110 lower 95 upper 105
glbp 10 weighting track 1 decrement 20
glbp 10 weighting track 2 decrement 20
i tested it ok
As i guess the problem is the weight value is not define the lower value, could you comments it?
BTW, could you tell me how to test the load balance, the tracert show alway use the same path to the destination , i need to clear the ARP in order to get the next path.
i tested the load balance option Weighted, Host dependant, Round robin, but i did not obvious the different and the effect. how to test it and monitor for each option
Thanks Again
Andy
12-19-2007 09:29 PM
Yes
Funny, you mentioned that - I had that in my config (while playing around) but it wasn't in your config.
glbp 10 weighting 100 lower 95
By default, the lower weight is 1. That definitely helps on the failover.
You need multiple devices and perform a traceroute to a destination via the GLBP
http://www.cisco.com/en/US/docs/ios/ipapp/command/reference/iap_d1.html#wp1013391
