ssh ASA over RA VPN
Dec 17th, 2007
I have configured RA VPN terminating on my asa 7.0(7). I am able to connect to RA VPN and also manage servers behind ASA using RDP, am able to ping inside interface IP but not able to SSH to inside ip,
thought I have added SSH command allowing RA VPN ips, and management-access inside both the commands.
here are some lines of my config.
ip local pool RAIPRange mask
ssh inside
any idea..
husycisco Mon, 12/17/2007 - 23:42
Hi Gaurang
Assuming outside interface is the termination interface for your RA VPN clients, which is pool for RA VPN clients can not be considered as inside. You should add the folloiwng
ssh outside
Maybe management-access inside works with this commadn and you might ssh the inside interface. Otherwise ssh to outside interface
gaurang_pandya Tue, 12/18/2007 - 02:07
Oh..i forgot to mention that..but I tried that already without luck. In-fact same config is working in another firewall that I had configured few months back..
husycisco Tue, 12/18/2007 - 02:33
Can you reach to inside interface via ssh from a computer inside?
