MPLS MTU and IP MTU on an interface
Dec 17th, 2007
I am working on a network running MPLS
MPLS MTU 1550 is set under gig interfaces while using show cef interface it shows that IP MTU is 1500
Will this cause some packet drops ?
Isn't it better to have same IP and MPLS MTU or not
thx
Overall Rating: 5 (1 ratings)
gauravprakash Tue, 12/18/2007 - 04:45
MPLS mtu means how big a labeled packet can be. so MPLS mtu will be bigger than ip mtu. Each label it has over IP packet wil add 4 bytes.
So its ok to have it, just keep it uniform across the network.
regards,
Gaurav Prakash
mounir.mohamed Tue, 12/18/2007 - 04:55
  • Gold, 750 points or more
It's depending on the MPLS application running on your network as each application (TE, VPN, Qos) add 4 bytes to the header for MPLS aplication labels.
