Problem to configure VPN
Dec 17th, 2007
Hi All,
I am having a problem in configuring a dynamic VPN in my pix which has the 7.2 version of ios but i am able to work with same configuration in the pix whch has 6.3 version i just want a user from outside my network using the vpn client access the resource inside my network below is my configuration is it ok are should i need to do anything more? please advice me.
ip local pool vpnpool1
crypto dynamic-map map2 20 set transform-set guatemala1
crypto map map1 20 ipsec-isakmp dynamic map2
crypto ipsec transform-set guatemala1 esp-aes-256 esp-sha-hmac
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption aes-256
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup Guatemalavpn address-pool vpnpool1
vpngroup Guatemalavpn split-tunnel inside_nat0_outbound
vpngroup Guatemalavpn idle-time 36000
vpngroup Guatemalavpn password xxxxxxx
access-list outside_acl permit tcp
route outside
access-list inside_nat0_outbound extended permit ip any
access-list 102 permit ip
nat (inside) 0 access-list inside_nat0_outbound
husycisco Tue, 12/18/2007 - 01:00
Hi Uday
6.3 and 7.2 are slightly different. First issue the following command.
isakmp enable outside
group-policy Guatemalavpn internal
group-policy Guatemalavpn attributes
vpn-idle-timeout 36000
vpn-session-timeout 10080
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value 102
tunnel-group Guatemalavpn type ipsec-ra
tunnel-group Guatemalavpn general-attributes
authentication-server-group LOCAL
default-group-policy Guatemalavpn
tunnel-group Guatemalavpn ipsec-attributes
pre-shared-key typeyourpresharedkeyhere
udayashankarsg Tue, 12/18/2007 - 01:22
Should i use your command after my command
if i enter following command i will get some error message
vpngroup Guatemalavpn password cisco123
udayashankarsg Tue, 12/18/2007 - 01:23
this is the error message
WARNING: the 'vpngroup' command has been deprecated, and will be converted to the corresponding tunnel-group and group-policy syntax
ERROR: ip pool vpnpool1 is not defined.
udayashankarsg Tue, 12/18/2007 - 01:50
if i try to connect after the configuration
the cisco vpn client asks for the Authentication after providing the local username and password of the pix and also i tried with username as Guatemalavpn and password as my preshared key i am get eroor saying
secured vpn connection terminated locally by the client reson 403 unable to caoonect security gateway
husycisco Tue, 12/18/2007 - 01:51
vpngroup is changed as tunnel-group in 7.x IOS. So dont use vpngroup and use my config instead. Rest of the config is OK.
When it asks you a username and password, submit a username password that you created in pix. For example following command creates a user
username uday password 1234 priv 1
udayashankarsg Tue, 12/18/2007 - 02:21
I am still having the same error and the below command is not working.
husycisco Tue, 12/18/2007 - 02:27
What error do you encounter when you type
Posting your running config would be helpful
husycisco Tue, 12/18/2007 - 03:41
Type the following in their respective order in configure terminal mode
udayashankarsg Wed, 12/19/2007 - 20:20
Do i have any problem with my crypto map command because when i type i get following error.
WARNING: dynamic map has incomplete entries
