AS5350 problem with POTS peer
Dec 18th, 2007
I faces with the problem in AS5350 which terminate calls from IP network to ISDN. Periodically cisco stops terminating a calls with disconnect cause "no circuit" (34). When I use "shutdown" and "no shutdown" comands in appropriate POTS dial-peer it become to work properly. How can I fix this problem ?
paolo bevilacqua Tue, 12/18/2007 - 06:09
  • Hall of Fame,
    Founding Member
Which exact IOS are you running ?
paolo bevilacqua Wed, 12/19/2007 - 02:14
  • Hall of Fame,
    Founding Member
Please upgrade to latest maintenance of 12.3 (like 40 or so, yu have 12).
Chances are, it's a bug been fixed in the meanwhile.
