Querying key pair failed
Dec 18th, 2007
%CRYPTO-3-IKMP_QUERY_KEY: Querying key pair failed
I've been getting this error non-stop on a Cisco 3725 routers. But the tunnel traffic is not affected. Any inputs?
didyap Wed, 12/26/2007 - 08:46
This error usually appears due to some misconfiguration at head end. Check if you have defined rsa key pair correctly. You should basically generate a private/public key pair on the local router and then copy the public key to the remote router. Also check if the isakmp policy is defined properly.
