12-18-2007 06:23 AM - last edited on 03-25-2019 09:25 PM by ciscomoderator
I have installed a CUCM 6.0 cluster with Unity 5.0. I would like to use TAPS to configure the phones. I need to configure CRS 4.5+ in order to use TAPS in the CUCM 6.0 world.
How can I do this if I don't have a spare server laying around? I tried the install on the Unity server, but installation aborted.
Thank you,
Ben.
12-18-2007 10:20 AM
CRS needs to be installed on Cisco Windows OS, similarly to Windows based CallManager. You also need approved MCS server, or OEM HP or IBM server.
Your other option is to install it on VMware if it's only going to be used for TAPS and not production CRS stuff.
Chris
12-18-2007 10:27 AM
Well I tried to install it on a MCS-7854-H2 server that has the Cisco provided Unity OS (Win Server 2003) and it was a no go.
Thoughts?
12-18-2007 10:42 AM
Unity is installed on regular Windows 2003 OS (media and platform config DVDs are provided by Cicso), as oppose to required OS such as:
2000.4.4
2000.4.4a
2000.4.5
2000.4.5a
2003.1.1
2003.1.2a
etc
These are Cisco modified Windows 2000/2003 platforms which have a lot of MS specific stuff stripped off. You need to install CRS on appropriate OS version.
Check out this compatibility matrix for more info:
HTH,
Chris
01-03-2008 07:55 AM
Chris,
Are there any available configuration guides for TAPS on a CRS server? I can't find anything that includes the steps needed to get TAPS up and running for CUCM 6.0 environment.
Any help would be apprieciated.
Ben
01-04-2008 12:51 AM
The TAPS configurations is located in the Bulk Administration guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t15taps.html
01-04-2008 08:41 AM
That is the problem...it really isn't. All that it says in this:
Configuring the Cisco Unified Communications Manager Auto-Register Phone Tool Application in CRS Applications Server
You can review the Cisco CRS 4.5 application server documentation by browsing to Cisco Voice Applications and Tools at http://www.cisco.com. Refer to the Cisco Customer Response Administration Guide for instructions on how to configure an application.
Additional Topics
See the "Related Topics" section.
That is not a configuration guide as to what I need to do with the TAPS install on the CRS server. The guide they refer to does not even have the word TAPS or Auto-Registration in the entire document.
Ben
03-19-2008 10:52 AM
I meet the same issue.
There aren't documentations.
After installing taps on CRS server I dont find the CRS script.
Do you solve your issue.
Best regards.
Thanks.
05-28-2008 07:53 AM
I was having the same issue trying to find out how to setup the script. It is diffent than the older version. You need to add it through the AAR Management. It creats the APP and uploads the script for you.
